    Jul 2006
    I encoded quicktime video in flash 8 using flash encoder. And I can see the video on website, but no audio at all!!!!
    I downloaded Dix codec, but still there is problem. I se MAC OS X what should I do?
    Try convert the quicktime to avi with with mpeg streamclip or quicktime pro and then convert the avi to flash.
    Jul 2006
    I tried to download quicktime alternative for free, but I can't find download page for MAC OS X. Is there quicktime alternative download for MAC??
    Aug 2005
    Palo Alto, California USA
    The short answer is no. QT Alternative is for Windows only; no Mac version exists. So, your options are limited. Baldrick's suggestions are good ones -- you should try one of those. Depending on what is inside your QT movie, you may or may not need to buy the $20 MPEG-2 codec from Apple. If the QT movie isn't in MPEG-2, then you can use MPEG Streamclip (free) to convert to avi without having to buy this extra component.
