Is there any setting to tweak before converting or is it just a lousy TV and you cannot do anything about it?
On computer screen everything looks great.
Or should I resize to 4:3?![]()
Thank you.
I see, many factors are involved, I got a bit smarter already
So I did some research. My source files are progressive mpgs, rendered by mainconcept encoder to interlaced mpgs in Vegas and authored through DVD Architect.
TV is PAL/Secam. Checked the dvd with two separate players, same problem occurs. I have to get some commercial disk to see the difference, maybe its the TV after all. I'll do that.
One question arose, I just read one another thread, that as I understand now, there's actually no need to render progressive material to interlaced for a PAL TV, cause dvd player will interlace it for the TV and picture will look fine. Is that correct?
But then why when simply rendering as progressive, the picture looks pixelated (if thats the right term) on computer screen, not sharp, low quality. If I render interlaced and blend fields and add some sharpening, it looks much better on computer screen. Why is that? -
Ok. So it means I should render as progressive and without deinterlacing, and then it should be fine. Am I correct?
Hello!
I got the problem solved. Actually my input material was from a new HDD Sony camcorder, so it was interlaced, upper field first.
So the flickering was from the fact that I forgot to change resolution to 16:9, so Vegas was rendering 4:3 and adding black frames to the video and that caused the flicker on TV. Also, I noticed that I was getting best results, when rendering to progressive and interpolate fields, picture looked more crisp and not so tiring for the eyes.
Although Im not understanding this. I mean, TV is PAL, interlaced, so why progressive video looks better than interlaced, when this is the native format? Is that the fault of crappy player?
So is that true that best is to render always progressive, so that you can then play those dvds nicely on computer and also on TV? Will it also be compatible with NTSC, is that dependent on player?
Thanks for the help.
black border problems
By nospam7676 in forum Video ConversionReplies: 2Last Post: 25th Dec 2010, 17:23 -
encoding black border or not ?
By miss in forum Video ConversionReplies: 1Last Post: 3rd Sep 2009, 10:27 -
black edge on netmeeting
By ahidayat in forum Newbie / General discussionsReplies: 0Last Post: 21st Mar 2009, 04:35 -
Black upper stripe flutters / flickers
By dynamique in forum Authoring (DVD)Replies: 0Last Post: 26th Sep 2007, 07:05 -
Black border around conversion
By trueman in forum Video ConversionReplies: 8Last Post: 26th Jul 2007, 06:50
