hey guys i want to burn some hd movies i use convertxtodvd to convert my usual movies and a liteon dvd writer to burn them. what do i need to do the hd ones? cheers![]()
ConvertXtoDVD will convert most formats, including HD. Of course, you will get a standard definition DVD from this.
If you want HD then you need to encode to an appropriate HD format, author to an appropriate HD structure (either HD-DVD or BluRay), then burn with an appropriate burner.
What is your source material ?Read my blog here.
its a hd dvd. i just found another post that explained most of it for me.
K-Lite Codec Pack messing up burning IMG audio cd burning
By Blå_Mocka in forum AudioReplies: 24Last Post: 26th Aug 2010, 05:27 -
Iso burning faile, folder burning succeed
By cd090580 in forum DVD & Blu-ray WritersReplies: 5Last Post: 3rd Dec 2009, 14:46 -
Problem burning data DVD using Nero 6 burning rom
By thebluekey_17 in forum Newbie / General discussionsReplies: 3Last Post: 19th Feb 2009, 13:14 -
Advantages - disadvantages to burning video folders or burning an ISO img
By theewizard in forum Authoring (DVD)Replies: 14Last Post: 26th Jun 2007, 15:19
