hi
just ripped a dvd with smart ripper,dvd2avi and then tmpgenc.
picture is perfect appart from being very jerky.
how do i get around the jerky playback.
what should the settings be in tmpgenc to stop this.
Not had this problem before.
thanks
dave king
You may have used the wrong field order when encoding.
http://www.doom9.org/mpg/tmpg_procedures.htm#fieldorder -
The_Flash is probably right with regards to the fields. There is even a simpler method for proper encoding then whats at "doom's"
Go here http://www.digital-digest.com/dvd/downloads/all_downloads.html and download a little program called BitRate Viewer. Install it, open the a vob of the main movie. Click the reading button to stop the program. In the bottom window it will tell you alot of things. It will tell you if the movie was encoded with a top or bottom field. Most of the time it is top field.
Also you need to go to the gop section and for intervals you need to type in 1 and for frames you need to type in 18. This to can make a difference in how your player decodes. In the quantize tab select mpeg standard and in the YUV select it. This will give you better color.
If you have blockiness in you encodes select under the quantize tab soften intra and non intrablock and go for a value of about 10-30. 30 if you are compressing the dvd movie alot.
This should get rid of the jerky frames.
SD DVD Played on Blueray Player
By wulf109 in forum DVD & Blu-ray PlayersReplies: 5Last Post: 17th Aug 2009, 09:36 -
no audio when played in DVD player? help
By cpeters12 in forum Authoring (DVD)Replies: 2Last Post: 29th Jul 2009, 17:01 -
I burn a DVD and then when played in a DVD player it cuts off after 50 mins
By uk_rose in forum Newbie / General discussionsReplies: 3Last Post: 7th Sep 2008, 21:43 -
Can a SVCD video file be burned on to a DVD and played in a DVD player?
By dvdnewbie64 in forum Newbie / General discussionsReplies: 9Last Post: 17th Apr 2008, 21:44 -
no audio on iDVD-burned DVD when played on a standalone DVD player
By patroklus in forum MacReplies: 12Last Post: 10th Apr 2008, 13:56
