I've tried a lot of methods to achieve the conversion in the topic title, but not one has given results.
Basically, I want to convert the mkv to a 360 compatible format with the least amount of re-encoding possible. The 360 supports x624 but only with 2ch aac audio, which is fine - I've been able extract the video and dts audio track (along with the subtitles and custom font) from the mkv container. I've also been successful in converting the .dts to an 2ch .aac.
My problem is in boxing them together in the .mp4 format : I've tried yamb, which fails (there's no error or log file, it just works for a millisecond and reports that it has completed, but no file is generated), and mp4creator, which successfully creates an .mp4 but the audio is about 10 seconds out of sync with the video.
Actually, that was after I'd given up on subtitles. The 360 doesn't natively support subtitles in a container, so I'm forced to burn them in - I couldn't find any prewritten program to do that for me, and I've never used avisynth, so unless someone can recommend a program, am I stuck with that? if so could someone direct me towards a guide for burning them in.. preferably retaining the quality of the original x624 file? (I have directVobSub installed, and the subtitles show correctly when I play the movie so I assume it would work)..
Could I just use a frameserver and encode audio/video that way? At least then I'd get the results I want without having to jump through 100's of hoops...
EDIT: I mean, can I just encode the frames/audio I would get from playing back in a normal mediaplayer (non-realtime of course) to the mp4/wmv codec?
anyone have any recommendations, how I would do it's, etc..?
BD rip to .mp4 with foreign only subs burned in.
By bonnstettermark in forum Blu-ray RippingReplies: 14Last Post: 14th Mar 2012, 10:44 -
[HELP][ANIME] MKV (H.264 + AAC) to AVI (PS3 - Compatible) with soft-subs.
By mooshimuushi in forum Newbie / General discussionsReplies: 4Last Post: 21st Aug 2010, 01:42 -
MKV with .ass or .ssa subs into mp4 for ipod
By lilly1991 in forum Newbie / General discussionsReplies: 0Last Post: 27th Jul 2010, 09:57 -
MKV to MP4 for PS3 with dual-audio (2ch AAC + 6ch AC3)
By sexyclient in forum Media Center PC / MediaCentersReplies: 0Last Post: 7th Dec 2008, 22:01 -
Export Subs [MKV - MP4]
By superpan in forum SubtitleReplies: 2Last Post: 19th Jul 2008, 05:04
