just bought a few dvd's from blockbuster, but wont to keep them in tip top condition. now im sure by law i can make a back up of something i own.
but usuing nero it wont copy. am i doing sumit wrong??
go on give a newbie a chance
You can use DVD Shrink to convert them to a standard DVD-5 disc. If you just do the main movie, it may fit or fit with minimal 'shrinking'. You may need to decrypt them first with DVDFab HD Decrypter if they are newer movies.
Optionally, you can use convert the whole movie to a DVD dual layer disk, just by decrypting, then using ImgBurn with a Verbatim DL+ disc and burn to dual layer DVD.
You don't really need Nero for anything. ImgBurn can burn the file from Shrink or do DL better than Nero most times.
BD -RE Discs
By pepegot1 in forum Authoring (Blu-ray)Replies: 3Last Post: 7th May 2011, 17:30 -
karaoke discs
By tanz in forum MacReplies: 0Last Post: 27th Mar 2010, 15:21 -
burning and playing blu ray/hd content onto discs onto dual layer discs
By julie_152 in forum Authoring (Blu-ray)Replies: 18Last Post: 21st Sep 2009, 14:36 -
Anybody used these discs?
By biged670 in forum MediaReplies: 3Last Post: 23rd Apr 2009, 04:30 -
Is copying gaming discs same as copy DVD/CD discs?
By coody in forum ComputerReplies: 24Last Post: 10th Jan 2009, 23:29
