I'm looking to buy a firewire card to transfer recordings from my motorola comcast hd-dvr. I don't know what pin count the hd-dvr has. I don't even know what type of firewire card to get for the pc.
I will be using it on a VISTA pc. How do I find out about firewire pin counts? I see they have 6-6 cables, 6-4 cables and 4-4 cables. Which is which?
Thanks in advance.
Results 1 to 10 of 10
Also check the Wiki for the Motorola box:
http://en.wikibooks.org/wiki/How_to_use_a_Motorola_DVR
Having just done this this past weekend, my Mot DVR was a 6-pin connector, as was the port on my PC, hence a 6-6 cable. Also, be aware that the Firewire spec limits cable length to 15 ft - any longer and you'll need to get a "repeater" cable. I got mine at Cable Wholesale, FWIW.
[Edit: also, if you weren't aware, fairly concise instructions/info here:
http://replayguide.sourceforge.net/dct6412/index.html - that's what I used to set up and capture to XP. Worked fine.] -
thanks ofbarea and jim44.
So jim44 - if I get a standard noname firewire card then all I should need is a 6pin to 6pin cable to go from the dvr to the pc? Sounds good.
Is this easily doable with vista?Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
I believe that's all. Just make sure the firware card is OHCI(?) compliant. That seemed to be the one key thing to look for when I bought a firewire card several years ago.Originally Posted by yoda313
Heck, I may still have it in a drawer, not currently being used. Email or PM me, and if I do have it, I can sent it to you.
Is anything easily doable in Vista? Sorry, saw the shot....Is this easily doable with vista?
Check the link in my [Edit] above, it should provide some help, either at that page or the links therein. I seem to recall it's doable, but I tended not to pay too much attention as I'm on XP.
Jim
[Edit (again): You may have to slog through the AVS Forum thread that's the first link at the Replayguide site, since it on references XP. Sorry about that.] -
Thanks jim44. I'll try to remember the ohci compliance bit.
I do have an xp machine but I'd prefer to use my vista pc as its got more power. Plus the xp machine is tehtered to my dsl router and wifi g router so I'd prefer not to have to move THAT around too often. Plus the vista pc has windows media center to boot
Hardware is easy, drivers are needed. This is an old step by step link. There are probably better links that others have found.
http://www.avsforum.com/avs-vb/showthread.php?postid=3818890Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
thanks eddv.
Warning for Vista. That driver referenced works in Vista but crashes to blue screen if a DV application is opened while the IEEE-1394 cable is connected to the Comcast box. I use my XP machine to avoid that happening.
Thanks eddv.
I bought the firewire card and cable today. Seems to be working just fine.
I found a link for the 3416 model and seems to be going good. I was able to recognize it and get it going.
As far as the dv notice thanks but I don't have a dv camera yet. Also if I were to do that I do have a liteon dvd recorder with a firewire input that I could use instead of vista. I would be able to do straight caps to the disc and edit later on the pc.
Are there any file size guides on high def captures for this hddvr? What is a typical 2 hour high def movie going to take to store it?
What size harddrive would I need for multiple movies? i think I might want to look into a 500gb internal harddrive. Would that be sufficient for capping off of firewire?
Also what about the possibility of spliting the file onto multpile dvdrs for storage? What I would like is to use either multiple single layer or dual layer discs and preserve the high def without downconverting.
Or since I think I may seriously leave my pc with my hdtv possibly converting to divx. Would h264 be better for storage purposes? Would it be conceivable to preserve 720p in a container format in a small enough file size to fit a dual layer disc? Would such compression be a waste of time and discs?
Any guides for this storage question would be appreciated. Thanks everyone.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw?
Don't Count AMD Out Just Yet (?)
By Seeker47 in forum ComputerReplies: 12Last Post: 14th Jul 2011, 17:43 -
Power Suppy 20 Pin and 24 Pin
By jollyjohn in forum ComputerReplies: 16Last Post: 3rd Jan 2011, 21:06 -
4-pin firewire ruined my Canon HV20
By Big Chupa in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 10Last Post: 12th May 2010, 13:20 -
Learn me count!
By Blå_Mocka in forum AudioReplies: 3Last Post: 18th Mar 2008, 17:26 -
24 pin PSU for a 20 Pin motherboard; Doh!
By Will Hay in forum ComputerReplies: 7Last Post: 5th Mar 2008, 12:02
