I have a 6.2 GB MKV file that is a HD quality video. I used ConvetXtoDVD to burn to a duallayer DVD, but after a long wait for the conversion, I got a box saying to insert a DVD+R DL disc, which I already did, so I put in another and the same thing popsup. The disc says it will hold 8.5 GB and the Audio/Video_TS folders say they are 8.01gb, so why won't they burn? I even went into Nero to try burning the A/V_TS folers to the DL dvd, but it says they won't fit. I've never used the DL type DVDs before, so am I doing something wrong? TY!
It's too big, you can only fit about 7.95 "computer" GB on a dvddl. See https://www.videohelp.com/dvd#dvdsizes
Can't you set a lower output file size in convertxtodvd? -
I also would not use ConvertXtoDVD to burn. Have it output to a folder, then use Imgburn to burn to Verbatim +R DL discs.
Read my blog here.
ConvertXtoDVD lets you choose DVD5, DVD9 or you can specify the size. I figured DVD9 would work, but I guess not. I'll use the custom size and then use Imageburn since I do have that available.
Thanks! -
I haven't had any issues with ConvertXtoDVD missing the file size targets in the past, but mkv can be an odd beast.
One thing to check - there is a tick box that will cause ConvertXtoDVD to copy the source files to the finished disc. This might push you over the limit, and also uses valuable bitrate. Check that you haven't turned this 'feature' on.
Finally, try loading the Video_TS folder into Imgburn to see what it says about the size.Read my blog here.
Trouble converting 25FPS MKV file to 24FPS
By dave in or in forum Video ConversionReplies: 3Last Post: 29th Jul 2011, 21:46 -
Having a lot of trouble converting a softsubbed MKV to a hardsubbed video
By Mental_Gear in forum Video ConversionReplies: 4Last Post: 26th Nov 2010, 14:51 -
Converting MKV causing trouble in Sony Vegas
By DaveFresco in forum Video ConversionReplies: 3Last Post: 4th Jun 2010, 04:23 -
trouble converting burning movie
By bimmerboy79 in forum Video ConversionReplies: 2Last Post: 8th Oct 2008, 07:35 -
Having trouble with converting mkv to mp4 in 1080p
By NoobyDoo in forum Video ConversionReplies: 40Last Post: 17th Jun 2008, 23:59
