Hi all,
I have recently been playing around with the best (read: simplest) method to convert DVD to avi for backup purposes.
I have narrowed it down to Xilisoft DVDRipper 4, which rips straight from DVD to Divx AVI (or other formats if I choose). It's fairly quick compared to some of the others, and doesn't have too many settings, and squishes files down really neatly. For my purposes (ie: not editing), it has taken much of the process complication out of the equation.
However, I'm having some oddness in playback, as follows:
- Realplayer plays the new AVI without a hitch (16:9)
- WMP plays it at 4:3
- VLC reports an error on opening: "This avi file is broken. Seeking will not work correctly. Do you want to try to repair it? (This might take a loing time)." If I say yes to repair it, it's not excessive time, and the file plays fine afterward, but isn't really repaired, because next time I open it, it has the same error again. If I say no to repairing, VLC will still continue and play the file without any other problems.
I suppose I should be grateful that I have figured out a simple process with a file that generally works. But obviously I would like to be sure that I am creating reliable files, so I am hoping someone can point me to why the file is playing inconsistently across players.
I am running Windows XP with latest codec packs installed.
Any thoughts ideas? I am happy to upload a short avi for people to look at if necessary.
thanks in advance,
~vvw
I would try something else like FairUse Wizard together with AnyDVD(to remove dvd decryption) or maybe DVDFab.
Common DivX DVD Players AVI Playback problems!
By Baldrick in forum Newbie / General discussionsReplies: 8Last Post: 6th Jun 2013, 10:32 -
Avid Meridien playback strangeness on MacPro
By cbarduck in forum MacReplies: 1Last Post: 12th Aug 2009, 13:10 -
how to convert wmv to avi for dvd playback[divx support]
By gundja in forum Video ConversionReplies: 4Last Post: 18th Mar 2009, 13:32 -
Divx (avi container) issues, jittery playback
By adam1972 in forum Blu-ray RippingReplies: 1Last Post: 19th Jun 2008, 19:46 -
MKV playback strangeness...
By mh2360 in forum Software PlayingReplies: 2Last Post: 16th May 2008, 18:56
