Hi all, I encoded an mkv file (the video part is XVID) to DVD. Well now I got the effect of interlaced COMB effect when I played in regular DVD player on regular TV (when there is movement the comb effect is more apparent). It never happen before (usually the effect can be seen a little bit when I am editing in tmpgenc but will not be seen on TV). Any tip on how to minimized the effect? I am using tmpgenc Express as usual. Thanks!
Just a by product of your conversion process. I had the same issue when using AviNet to convert DVD to avi. Switching to AutoGK solved my problem.
All I'm really saying is to try a different tool for the conversion. Of course, I am sure someone here has more experience with tMPGenc and can assist you with that tool.Google is your Friend -
Thank guys. I will try alltoavi. BTW is there any advantage of encoding the video in progresive mode? I mean I put tmpgenc to always deinterlace and progresive? WIll it play in ordinary TV with non-progresive DVD player?
Edit: Is this tool to convert all to AVI? I want to make mpeg2 (so it can play in regular DVD player) so I need to encode it again after I convert to avi?
What would you do with this captured video? (Comb-like problem)
By Asterra in forum Capturing and VCRReplies: 7Last Post: 6th Sep 2011, 12:13 -
TV problem: comb-like appearance
By draushaus in forum Newbie / General discussionsReplies: 0Last Post: 1st Jul 2010, 14:38 -
3D Comb Filter and Pass Thru
By RidgeShark in forum DVD & Blu-ray RecordersReplies: 2Last Post: 14th Jun 2010, 23:36 -
'Combing' effect when playing VOB files with Media Player Classic
By djdust in forum Software PlayingReplies: 1Last Post: 16th Oct 2008, 21:23 -
Will the digital television (DTV) deadline effect on the DVD player?
By coody in forum DVD & Blu-ray PlayersReplies: 2Last Post: 4th Oct 2007, 11:18
