Hi guys,
I am trying to create a college project. I started a movie that was being played through realplayer (speed 23.976). I set a stopwatch against the realplayer timing. I cannot understand why that after an hour there is a time difference between the two times (in this case the avi was 8 minutes behind the stopwatch). Understanding this disparity is integral to my project. If anyone can help I would really appreciate it. Below are my questions:
1. Is there a difference in the time displayed on realplayer between playing a PAL DVD and NTSC formats? If so, what is the percentage difference between each format against a 'proper' second?
2. Would realplayer play media with different framerates at the same speed? That is, would the elapsed time displayed with realplayer remain the same for media played at 29.97FPS and 25FPS? Again, what is the percentage difference between each format against a 'proper' second?
3. AVI media typically comes in at the speed of 23.976FPS. But doesn't NTSC actually run at 29.97? Why would I slow the framerate from 25 to 23.976 to get NTSC when I want the speed to be 29.97?
4. What would I need to do to convert media of 23.976FPS to 25FPS?
I have more questions but if you can help with these that would be great!
Thanks,
Rosie
NTSC and PAL are irrelevant on a PC. A 5 minute clip in NTSC or PAL will still be 5 minutes on a PC. Time displayed when playing video files can be affected by the file index. You can often also see differences in playback time between various video playback software.
Google is your Friend
RealPlayer Downloader
By oicram in forum MacReplies: 0Last Post: 15th Oct 2011, 12:14 -
Using RealPlayer on XP vs Win 7
By solarblast in forum Software PlayingReplies: 5Last Post: 10th Jun 2011, 09:06 -
MKV Codec for Realplayer?
By adrian2055 in forum Software PlayingReplies: 3Last Post: 27th Jul 2010, 09:03 -
Pb watching WMP / realplayer on TV
By siljan in forum Newbie / General discussionsReplies: 2Last Post: 24th Jun 2008, 04:26 -
convert to Realplayer with Premiere?
By rocko918 in forum Video ConversionReplies: 0Last Post: 16th Jan 2008, 11:30
