I recently bought a new drive and I don't know what folder Vegas uses to store its temporary files, but would changing the value of both TEMP and TMP folders under "Environmental Values" to the location of my new drive work? Or is there another way I can use my new drive as the primary drive for temporary files?
That depends on how much filtering and effects work you plan to do. Rendered clips are stored as tmp files.Originally Posted by seven_deuce offsuitRecommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
It depends on the size of your projects. For most work it is probably overkill, but if you have multiple large projects on the go at once you might need a bit.
You also gain more performance putting your temporary files on a different drive. Partitions can make management easier, but they offer nothing in the way performance because you are still using a single drive and working the heads back and forth.Read my blog here.
Actually, I set the temporary files folder to my new drive apart from the drive that I was originally using. So should I just set it as one huge partition instead of splitting the drive into 4?
Need guide on converting temporary video
By mazeer in forum Video ConversionReplies: 4Last Post: 6th Jan 2011, 02:25 -
Temporary video recovery. Help, please :-)
By Stoiko in forum Newbie / General discussionsReplies: 4Last Post: 19th Nov 2010, 00:39 -
does anyone know where Super stores temporary files?
By Onceler2 in forum Video ConversionReplies: 1Last Post: 18th Jun 2010, 13:51 -
IE Temporary Internet Files Build-up
By hech54 in forum ComputerReplies: 3Last Post: 17th Feb 2010, 11:07 -
YouTube vids now not showing up in Temporary Internet Files folder...
By brassplyer in forum Video Streaming DownloadingReplies: 4Last Post: 18th Sep 2008, 00:09
