I want to copy my Planet Earth DVD’s and get the best results. I don’t care about the peripherals, I just want to be able to bring up a menu with the 3 titles on each disk & be able to choose which one I want to view. Also what is the best software to use on this and other purchased DVD’s to insure the best results. Do I use different software to put it on the Hard Drive and then Shrink it? I’ve noticed a lot of you recommend DVD Shrink & DVD Decrypter, are these pretty reliable and if so is there instructions for Dummies (not that I’m a Dummy, but for the sake of argument let’s say I am) that will tell me all I need to know to get great results.
Uncle Bob
Uncle Bob
If you want the best results then you want to copy the entire disc to your HDD, then write it back to Singapore manufactured Verbatim +R DL blanks. This way there is no quality loss at all. Anything else is a compromise.
If you do have to write them to DVD5s, then I would
Rip with DVDFab HD Decrypter
Re-author with VOBBlanker to strip out the unneeded material
Re-encode with DVD Rebuilder and the HCEnc encoder
Burn with ImgBurn
Guides for each tool can be found in one of the following :
1. The tools page for that tool
2. The User Guides forum
3. The HOW TO section (to your left)Read my blog here.
What's your favorite Planet of the Apes movie?
By johns0 in forum PollsReplies: 19Last Post: 17th Sep 2011, 15:07 -
Planet Earth each m2ts file playing same episode
By mwsolomon in forum Blu-ray RippingReplies: 0Last Post: 17th Feb 2009, 23:16 -
combine 'Planet Earth' discs
By MCEStaff in forum Blu-ray RippingReplies: 2Last Post: 7th Feb 2009, 18:20 -
? “Planet Earth” Encoding Question
By Synetech in forum DVD RippingReplies: 8Last Post: 10th Apr 2008, 00:58 -
I [AM STILL] the biggest dumbass on the planet [UN-FIXED!!!!!]
By Will Hay in forum ComputerReplies: 27Last Post: 13th Mar 2008, 15:37
