Hello everyone,
I have been usining Premiere Elements 3.0 to edit my video projects. I have used the software to prepare DVD's but found it rather time consuming. I thought it would be better to encode to mpg2 (720X480, NTSC) and then take the mpg file and use a different authoring software : cyberlink power2go to prepare the DVD. Unfortunately, the software doesn't recognize the file.
I could reencode using Super to a smaller aspect ratio, but I see a loss in quality. Is there anyway to produce the files out of Elements to make them work in other authoring software.
What I would like to do is prepare several mpg files and then author them to a DVD. I've found doing this on Elements is tedious. The Power2Go software is simple enough, but I can't make it recognize PE 3.0 mpg files.
my system :
Pentium 4 3.0 GHz
1 GB memory
160 GB HD
Radeon AIW 9600
thanks
compaqted
What do you mean "smaller aspect ratio"? DVD can be 4:3 or 16:9.
What are your other encoder settings?Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
thanks for the response.
I did a little checking, it wasn't a change in aspect ratio, but the number of frames was changed from 29 to 25..
how would that make the file more readable by another software package...
confused
compaqted -
Keep settings to limits set by the DVD standard
https://www.videohelp.com/dvd
NTSC DVD frame rate must be 29.97 for 480i or 23.976 for 480p.Recommends: Kiva.org - Loans that change lives.
Adobe Premiere Elements
By willmington in forum Newbie / General discussionsReplies: 5Last Post: 5th Jul 2011, 04:14 -
Looking for alternative to Adobe Premiere Elements...
By Heyjoojoo in forum Authoring (DVD)Replies: 4Last Post: 27th Jan 2010, 14:34 -
Slow editing process with HD-mp4-files-Adobe Premiere Elements 4.0
By Mållgan in forum EditingReplies: 1Last Post: 12th Oct 2009, 17:27 -
Adobe Premiere Elements sucks?
By llRekcusll in forum Newbie / General discussionsReplies: 12Last Post: 12th Feb 2008, 13:35 -
By pepegot1 in forum EditingReplies: 12Last Post: 28th Sep 2007, 11:59
