Okay, so I have some RMVB files that I'm trying to convert to DVD, everything was working fine until sometime recently where all the files that I converted were missing the audio (so no sound). The file works perfectly fine when I play it with RealPlayer on my computer. I've always used Winavi Video Converter and everything worked fine...until now. I've tried Cucusoft Video Converter but I have the same problem, I've also tried dling some all in 1 codec pack that was reconmended somewhere but still no luck. I'm guessing Winavi doesn't support the certain audio stream that my file uses...
I used AviCodec and got all this info
File : 213 MB (205 MB), duration: 0:43:51, type: RMF, 1 audio stream(s), quality: 41 %, ,
Video : 185 MB, 592 Kbps, 25.0 fps, 640*480 (4:3), RV40 = RealVideo 9, Supported
Audio : 20 MB, 64 Kbps, 44100 Hz, 2 channels, 0x0 = RealAudio 8,cook-24, , , Supported
Any solutions on what I need to do to get the audio in there again? Thanks in advance
	Works fine, thanks alot..only problem is I'll have to buy it >.<, nevertheless, thanks for taking your time to help!!
  RMVB conversion end up without audioBy alc112 in forum Video ConversionReplies: 22Last Post: 14th Jan 2010, 01:34
  Extract audio and edit from RMVBBy sychern in forum Video ConversionReplies: 1Last Post: 16th Oct 2008, 04:45
  Dual Audio in RMVB files?By bAz666 in forum Newbie / General discussionsReplies: 8Last Post: 12th Feb 2008, 22:18
  RMVB audio and MPCBy MasterRoshi in forum Newbie / General discussionsReplies: 3Last Post: 26th Jan 2008, 11:41
  There is no audio on .rmvb file during playbackBy Aayanna24 in forum AudioReplies: 2Last Post: 23rd Sep 2007, 19:40
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
