Hi..i trying out gotsent to convert my mkv files to mp4 to view om ny xbox360,the conversion go fine and the file play's in wmp11 just fine but none of the files i have convertet will play on the 360,have tried whit safe sync also,and the nero acc dec in the gotsent dir,have ac3 filter installed....anythig i can check that i'm doing wrong,or what?all mkv files i do convert in mediacoder using the apple tv extension works just fine,but take for like ever
Results 1 to 12 of 12
Looks like that tool converts files for use in a PS3. At least the notes state ONLY for PS3.
Google is your Friend -
Did you make sure to check "Split over 4GB". I had a few files that wouldn't work and it was because the final output was over 4GB. Even playing through the network this seems to be an issue. Reconverted with that option checked and everything works fine. I have a 100% success rate after converting 9 files.
Another thing to check. And this is especially true if none of your PC programs can play the resulting .MP4 file. Make sure that the file name is simple. I've had a few files where the name was very long and "complicated" and the file wouldn't play on the xbox or on my PC. You can't simply rename the .mp4 file, you must rename the original .mkv file and reprocess it. I guess one of the program's along the way can't handle the name and messes it up.
I have an interesting problem, it seems to work fine converting, but when it says complete, there is no movie in the folder I told it to output to? Any ideas?
Same thing happened here:Originally Posted by xbox360dude
https://forum.videohelp.com/topic343915.html
I see that you're using Vista too
thanks, i think i might try virtual pc, if it works, it will solve some other problems too.
trying to run on virtual pc with xp sp2, and getting runtime error 5.
Ivalid procedure call or argument.
what is the deal? Installed gotsent, ac3 filter and halisplitter on virtual pc. -
churchie have you by chance noticed any of the mkv files that have subtitles embeded causing any problems. trying to watch eastern promises and the mkv has english subtitles included, i know gotsent puts these in the mp4 even though currently the ps3 and the xbox360 cant read them. but in all the other movies ive converted so far i dont remmember any having subtitles. or it could just be that the output file is over 4 GB like you said. all my others were just under 4 GB. im trying to split it now ill post back with my results.
Any luck with Eastern Promises? It may have been the 4GB file like you mentioned. I have converted a few files with subs included, and none have cause problems.
hi! i know this is a little off topic but im just thinking if maybe any of u could help me.
so ive been using gotsent (version 0.24 beta 6) for a couple of months now and it has worked out pretty well so far. i have already converted a bunch of videos and most of them are playing perfectly on my xbox360. well my problem occured when i was trying to convert an mkv hd video that was encoded to have the 'russian' & 'english' as the audio track choices with 'russian' being the default audio track. just to be sure, i tried playing the video using the 'english' track and its working really well so i thought maybe i could proceed then to conversion. so i opened the GOTsent program and saw that i can choose which audio it will use for the final converted video so i chose 'eng' (which i suppose meant to be 'english' since the other option was 'rus' which i think means 'russian'). when it finished converting, the language of the final converted video was still in 'russian' and apparently, that's the only audio track that it has. i already did it twice and double checked to see that i chose 'eng' but still, same result. i hope somebody can help me out. thanks in advance!!!
GotSent Problem
By MultiNikos in forum Video ConversionReplies: 8Last Post: 29th Jan 2012, 15:36 -
Gotsent Problem
By MCBarkingSpoon in forum Video ConversionReplies: 6Last Post: 17th Oct 2011, 05:23 -
Gotsent converstion problem
By Bigm1ke in forum Video ConversionReplies: 1Last Post: 6th Jul 2010, 21:08 -
GOTSent Problem
By zac5876 in forum Video ConversionReplies: 1Last Post: 28th Feb 2010, 11:36 -
GOTsent audio problem
By zunichi in forum Video ConversionReplies: 3Last Post: 9th Apr 2009, 20:46
