  1. Has anyone successfully got this to work? I have found sites in Spanish avbout it, but unfortunately do not speak it enough to understand it. If it truely will do Mpeg2 and fit an entire movie on a 80 min CDR, I would like to know how to do it. Thanks! :D
  2. easy, use a bitrate calculator, and lower the avg bitrate to appropiate level in order to fit that amount of time on the disk.
  3. Where would i pick up a bitrate calc at? And what would it be called? Thanks again.
  4. Look to your left, under the section called TOOLS
