I have a bunch of small DV files that I wish to join together. Does anyone know a simple way to do this with one command or tool so that I don't have to join them manually?
You can append them in virtualdub, then output using DirectStreamCopy mode so you don't have to re-encode.
Read my blog here.
Anyone knows how to write such a batch script for Avisynth that doesn't involve typing each filename?
I don't think you can select multiple files to append in VirtualDub, that's why I asked. -
If you need to do this often, you can use a file renamer such as this: http://www.download.com/3000-2248_4-10703208.html That speeds up the process when you need sequential file names for joining.
batch dvd ripping - output folder to input folder?
By mkv2avi in forum DVD RippingReplies: 5Last Post: 17th Apr 2012, 16:23 -
Best way to batch convert xvid/avi files to mkv/x264 files?
By gaikokujinkyofusho in forum Video ConversionReplies: 1Last Post: 13th Jan 2012, 06:31 -
Join AVI files??
By bagmand22 in forum Authoring (VCD/SVCD)Replies: 16Last Post: 14th Feb 2010, 03:42 -
join several avi files
By hilario in forum EditingReplies: 2Last Post: 13th Nov 2009, 12:49 -
Using Submerge to Join avi Files to srt Files: Problems with Export
By TiggyWink in forum MacReplies: 1Last Post: 26th Jun 2007, 08:16
