I have a xvid that is wide screen and I was wondering if there is a way to convert it to a regular screen size?
Sure, by cropping off the sides of the video. Not really recommended, though.
The video 'action' may end up at the missing 'sides' of the screen and not be visible.
It's better to just view it in wide screen mode, even though it will be a smaller picture. Or use your player settings to adjust or zoom it to a bigger picture.
A better alternative is 'pan and scan'. This is where the video 'frame' is moved back and forth to cover the main part of the action. This is still highly unpopular with most video affectionatos. Here's one view on the subject: http://www.widescreen.org/examples/starwars/index.shtml
But, depending on the format, you can crop with VirtualDub or similar and re-encode with some quality loss if you want.
screen slightly too wide
By JohnnyBob in forum FeedbackReplies: 14Last Post: 27th May 2011, 10:49 -
DVD Lab Pro, help mixing full screen and wide screen.
By stantheman1976 in forum Authoring (DVD)Replies: 4Last Post: 31st May 2009, 17:23 -
DVD picture doesn't fill screen on new wide-screen TV
By ibzomie in forum Newbie / General discussionsReplies: 7Last Post: 16th Aug 2007, 03:37 -
converting wide screen to full screen. HELP!!
By arjunkkalra in forum Newbie / General discussionsReplies: 7Last Post: 23rd Jul 2007, 12:41 -
wide screen
By ht0160 in forum Authoring (DVD)Replies: 16Last Post: 18th May 2007, 16:52
