K.. after wasting an entire saturday screwing with this, Im tired and I want to be done..
I have enough hard drive space (just) to just make all this stuff Ive captured uncompressed RGB/YCbCr AVI files.
Will iMovie have any issues opening/editing these?
thanks,
nopk
I cannot speak on iMovie '08 because I don't have or use it,
but as far as iMovie 06 HD, and iMovie 4 which I have in front
of me, both will have to take your avi files and convert these to
DV stream files, for them to be able to use them.
So, if you have an uncompressed RGB/YCbCr AVI that is
say 48 GB, iMovie 4 and iMovie 06 HD will need to have another
48GB of space available to load the file and convert it to DV
for it to use, making for a total of 96GB of space to be used.
Since I missed your original posting, I don't know how much
available hard drive space you have, but if your planning on
using iMovie to edit these, and it's iMovie 06 or earlier, you
would be better off having the files as DV Stream, or
have iMovie import the footage in from your camera directly."Everyone has to learn, so that they can one day teach."
When I'm not here, Where can I be found?
Urban Mac User -
What kind of uncompressed file is this?
Basic rules:
1. Compressed formats need proper codecs and lots of CPU and/or dispaly card hardware support to play smoothly.
2. Uncompressed files need very fast disk drives up to fast RAID with multiple sync'd drives. Playback to a port (e.g. SDI) is possible. Playback though the display needs system analysis. Just because you can download an uncompressed file in no way means you can play it real time.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
yeesh, what a pain.
well, screw it.. Ive decided to use mpeg streamclip to convert everything into Quicktime DV and just cross my fingers that bro-in-law can work with it.
thanks for the input all..
nopk
Exporting from uncompressed AVI to uncompressed MOV
By courtneye in forum Video ConversionReplies: 0Last Post: 9th Jul 2010, 09:20 -
What software will convert my AVI files to something I can read in iMovie
By Quinn82 in forum MacReplies: 8Last Post: 12th Feb 2010, 17:38 -
Sequencing my DV from Analog to AVI to iMovie. Format? Compression?
By kiararden in forum Video ConversionReplies: 4Last Post: 2nd Oct 2009, 11:20 -
Compressing an uncompressed AVI (adobe premiere pro)
By marcos316 in forum Newbie / General discussionsReplies: 1Last Post: 19th Jan 2008, 23:07 -
Forget the OS: Mac, Linux, Windows, ?,,, It's the Desktop Search stupid!
By SpectateSwamp in forum Off topicReplies: 2Last Post: 20th Jun 2007, 15:14
