I have an Xbox 360 and have been struggling converting DVD's to WMV so I can stream them to my XBOX 360. Now that the XBOX 360 supports Div/Xvid I would like to use that conversion since it seems to be a much better supported conversion. I would like to keep the surround sound 5.1 capability with my videos. Does anyone know of a good all in one movie that will either convert directly from dvd or from decrypted VOB's on my HD. Of course I would prefer free but do not mind paying for something if it means I do not have to manually perfom many steps. My main concern is to rip the main movie at fairly good quality..ie 1.4 GB per movie with 5.1 sound. I did a search but did not really find anything which specified its ability to output 5.1 sound and a tutorial on how to do that. Thanks in advance for any help which can be provided.
Thanks,
Mark
Why to WMV? better to x264....IMO....
http://www.digital-digest.com/articles/Xbox_360_H.264_Conversion_Guide_page1.html
0..pretty darn cool.....
But if you must have WMV,
http://www.digital-digest.com/articles/AVI_to_WMV_Xbox_360_Conversion_Guide_page1.html
But you'll have to convert DVD to avi first...." Who needs Google, my wife knows everything" -
I do not think x264 supports 5.1-6 channel and does not stream natively to Xbox360 the way DivX , XviD or WMV do. I used DVD-WMV but constantly had audio delay problems of up to 2 seconds and never received help on that site so I gave up.
Are u sure the xbox360 supports 5.1 in streamed media.
I quote "PS3 has an advantage over the Xbox 360 in that it supports AAC 5.1 channel audio (although with limited decoding support)."
Also: "The Spring 2007 Dashboard update for the Xbox 360 adds H.264 playback support.""Youth is wasted on the young." -
From the XBox team FAQ...
What are the different ways to play video content on Xbox 360?
You can play video from a USB 2.0 FAT32 removable drive, optical media, and by streaming from the Zune software, Windows Media Player 11, or Windows Home Server.
Do you support 5.1 channel AAC?
No. Only 2-channel AAC is supported. If you want to play a 5.1-channel video on your console, you will need to encode it to WMV with WMAPro 5.1 audio or use the AVI container with Dolby® Digital 5.1 audio.
http://blogs.msdn.com/xboxteam/archive/2007/11/30/december-2007-video-playback-faq.aspx" Who needs Google, my wife knows everything"
Increasing Audio volume on AVI/DivX/Xvid with AC3 Audio
By Spacedementia87 in forum User guidesReplies: 21Last Post: 24th Dec 2021, 07:21 -
Rip DVD to Divx/Xvid with AC3 Audio
By dudeman316 in forum DVD RippingReplies: 6Last Post: 3rd May 2009, 03:25 -
How to convert AVI/DivX/XviD with AC3 to DVD with AC3
By Baldrick in forum User guidesReplies: 52Last Post: 21st May 2008, 19:22 -
Easiest way to make a 16:9 DVD into a 4:3 XViD?
By bconnolly in forum DVD RippingReplies: 10Last Post: 31st May 2007, 15:54 -
Easiest TV Show DVD to Xvid Solution?
By nickolasj80 in forum DVD RippingReplies: 1Last Post: 28th May 2007, 13:07
