I'm using SureThing labeling software to create wrtwork for my Lightscribe discs and making some for a DVD case also. I can export as an image file but what's the best resolution to save as for a full size DVD case?
Also, if I take the file somewhere like Office Depot to print it on glossy paper are there any tricks or tips I or the employees should know to get it to print correctly and look the best we can get?
For DVD inserts, I use CoverXP and print myself them myself. It isn't necessary to use glossy paper as the clear plastic of the case will determine the cover appearance. What you want is a paper that will print in high quality to capture the details. I use this paper: http://www.newegg.com/product/product.asp?item=N82E16828103049
Actual sizes will vary depending on the type of cases that you are using.Google is your Friend
What's some good paper for DVD inserts?
By slayerbizkit in forum MediaReplies: 13Last Post: 21st May 2011, 10:01 -
How do I print out a DVD cover?
By orfajackson in forum Newbie / General discussionsReplies: 8Last Post: 13th May 2009, 15:33 -
External case - 3.5 or 5.25 case....
By kenmo in forum ComputerReplies: 3Last Post: 2nd Jan 2009, 16:54 -
CD Jewel Case Inserts...best pricing?
By ChaunceyK in forum Newbie / General discussionsReplies: 0Last Post: 3rd Nov 2007, 15:10 -
printing DVD cover inserts
By WhiteKenny in forum Off topicReplies: 2Last Post: 8th Aug 2007, 16:56
