http://www.shop4tech.com/item2536.html
I wanted to buy them but I can't imagine the results... do they look good printed? or should I stay with plain white?.
1f U c4n r34d 7h1s, U r34lly n33d 2 g3t l41d!!!
Its hard to explain, but they do look pretty killer if you are using photo/art type graphics on them & covering the whole disc.
Some things do look better than others printed on silver printables but it depends i guess on what you are putting on them.
I remember trying to scan some but the scans did not do the actual disc justice.
The first time i bought them i got a sample 5 pack from somewhere to test them and then i started using them almost exclusively for dvd's and cd's. -
Thanks for the info, I will give them a shot!.
Epson R220 problem printing on discs
By nwo in forum MediaReplies: 3Last Post: 2nd Jun 2011, 14:15 -
burning and playing blu ray/hd content onto discs onto dual layer discs
By julie_152 in forum Authoring (Blu-ray)Replies: 18Last Post: 21st Sep 2009, 14:36 -
Printing problem
By CSULB71 in forum ComputerReplies: 41Last Post: 11th Jun 2009, 21:06 -
Is copying gaming discs same as copy DVD/CD discs?
By coody in forum ComputerReplies: 24Last Post: 10th Jan 2009, 23:29 -
lightscribe Printing
By baqar in forum MediaReplies: 3Last Post: 29th Feb 2008, 14:24
