    Feb 2002
    Newcastle, UK
    Hi
    Im trying to convert some avi's and this program is working, sometimes!
    I am following the tutorials on this site but
    TMPGEnc 9 out of 10 times doesnt work!
    I dont know if its luck or what but whatever it is its bad! :cry:
    Ok what is happeneing is that TMPGEnc either freezez or re boots my PC!
    Anyone else had this problem?
    On one avi it keeps freezing at the same point.
    On another it re boots at different points!
    Can anyone help me?
    Cheers
    Scottio
  2. Member SanderMan's Avatar
    Feb 2001
    Netherlands
    I sometimes have the same problem. It seems that it has to do with the audio encoder. If I use TMPGenc without audio it doesn't freeze or reboot my pc. Try using an external audio encoder or encode the audio with another program and then Multiplex the video and audio.
    Good luck,
    SanderMan
