What is the best codec pack to run WMP11 on winxp pro? Also when playing video it looks washed out?
For best results, AVOID codec packs. When you have a file(s) that won't play, open the file using Gspot or mediainfo and find out which codec(s) is needed for playback. Then download and install only the needed codec.
Washed out video can be a result of the video adjustments within the player, or the video overlay settings of the video card drivers.Google is your Friend
Wmp
By aaahza in forum Software PlayingReplies: 1Last Post: 23rd Feb 2011, 03:03 -
H264 Playback Problems in WMP 11
By seasonsofwither in forum Software PlayingReplies: 3Last Post: 21st Dec 2009, 22:49 -
Vista Enterprise problems with WMP 11
By jyeh74 in forum Newbie / General discussionsReplies: 11Last Post: 22nd Mar 2008, 19:18 -
WMP
By marlo in forum AudioReplies: 0Last Post: 23rd Nov 2007, 15:50 -
Audio Sync problems with MKV file using WMP
By jradams76 in forum Software PlayingReplies: 0Last Post: 23rd Jul 2007, 11:51
