I am attempting to convert an AVI movie to a burned DVD. According to the how to I have first converted the movie file to the DVD ffmpeg format. At this point the movie plays fine with sound and all. Then I go to convert it to the disk img file using the img tool. The resulting image file is only roughly 2 GB as opposed to the DVD ffmpeg format which put out a 4 GB file. Then when I use VLP player to watch the img file I only get video and no sound. What am I doing wrong?
This shouldn't happen. The img tool images a UDF formatted DVD from the VIDEO_TS folder, and the img file should be slightly larger than the VIDEO_TS folder, because of overhead.Originally Posted by thecougfan
Note that the img tool may put the img file inside the DVD folder, so don't compare the DVD folder size with the img file size, as that would double it!
VLC and Apple DVD Player should be able to play the VIDEO_TS folder, as well as the mounted counterpart of the img file.
Please confirm if you selected the parent folder of the VIDEO_TS folder for imaging with the img tool. And remove the img file on a second try, as it doesn't belong inside the parent folder.
The only way that I can think of for getting video without audio, is if you try to play the .m2v file (which is video only) in VLC.
An empty AUDIO_TS folder is normal for DVD-Video. The AUDIO_TS is only in use with DVD-Audio discs (very high-fidelity audio, e.g. 96 kHz sampling rate audio discs).Originally Posted by thecougfan
help me how to make a set of avi files to DVD with menus of each avi file
By mmah in forum Video ConversionReplies: 5Last Post: 9th Mar 2011, 02:07 -
Found DVD/AVI software player that displays Chinese srt subtitles with avi
By jimdagys in forum Software PlayingReplies: 1Last Post: 14th Nov 2009, 19:45 -
Create Root menu for avi's on DVD without converting each avi?
By Ghtpua in forum Authoring (DVD)Replies: 2Last Post: 7th Sep 2007, 23:23 -
I have converted avi to vcd and svcd im looking to convert avi to dvd
By dbztoolkit in forum Newbie / General discussionsReplies: 1Last Post: 11th Jun 2007, 12:14
