    Dec 2007
    I am having some issues with my videos for some reason none of them display the info when I right click and go to properties it says that the file has no summary properties but yet when I play the files in the WMP or Divx Player or open the avi files with video inspector the in fo is there also for some reason the files will not display as a thumbnail within the folders well thanks for any help that can be given
  2. Banned
    Jun 2007
    UNREACHABLE
    Probably some settings of Windows Explorer were screwed up by
    the programs you have installed and uninstalled. I have the same
    "problem" as you, but I consider it a good thing, because "shell integration"
    is resource-consuming, and also because the automatic info about the media files
    on your computer may be very incorrect.
  3. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    The summary page as never been of much use for anything beside Office documents.
    /Mats
