If I have a video at 23.8 frames per second, and I convert it to 25 frames per second, what happens? Will it change the quality of the converted file? The size maybe? Or have no noticeable effect?
I'm using vista 64 unfortunately, and to get the video onto my iPod and avoid the bad atom QuickTime bug, I have to change a files fps to get rid of the 64-bit time signature or something...
Why would you want to convert it to 25fps? It won't normally effect the quality or the size, but it may be unplayable on a set top NTSC player. Vista 64 won't have much to do with it, though you may have less programs available for conversion.
So what you really want to do is to convert it to IPod format? Have you looked in our 'Portable' tools? https://www.videohelp.com/tools/sections/portable-mobile-psp-ipod
You may find a program there that suits your purpose. SUPER is one that's converts most formats. -
I can manage to convert the files no problem (using videora or prism); itunes is more the trouble.
When converting a file to h.264 in vista, and then trying to add that file to itunes, you will often get an error stating the video has a “bad public atom.”
I've read that this has to do with the way Apple employed the h.264 specification, and the only known fix for the time being is to change the framerate of the file when converting (which has worked perfectly for me so far!).
I’m just more looking to understand what happens when one does such a thing? If increased, will the newly converted file repeat frames or something? Does it chop up the video at all? Does it take more processor power to play the video (which will drain the ipod battery faster) etc.
Framerate conversion (again sorry) 60p to 25p this time
By Panash in forum Video ConversionReplies: 5Last Post: 2nd Jan 2010, 18:32 -
Framerate Conversion
By rackball in forum Video ConversionReplies: 10Last Post: 11th Aug 2008, 05:04 -
Framerate Changing to 30.1328?
By tacman1123 in forum EditingReplies: 0Last Post: 22nd May 2008, 15:22 -
Audio framerate conversion?
By pYShTr in forum AudioReplies: 2Last Post: 28th Jun 2007, 12:05 -
Super fast video playback - framerate changing, timeshifting
By KOJV in forum Newbie / General discussionsReplies: 2Last Post: 7th Jun 2007, 00:20
