Hi.
Some questions on TDA3:
1. If I want to merge 2 DVDs into one, can I merge each full DVD's contents including menus/submenus etc too? Or is it movie only?
2. If I want to make DVD compilation with MPEG/AVI files as input, can I import the DVDs chapter points (e.g. from PGCDEMUX)?
3. If I want to make DVD compilation with MPEG/AVI files as input, can it accept .SUP subtitle files (e.g. from PGCDEMUX)?
Hi.
I would like to know more about Q2 & Q3's answers.
2. The input I had in mind here is normal MPEG or AVI/DivX & not VIDEO_TS folders. So can I use a celltimes.txt to set the chapter points or do I have to do them manually in TDA3?
3. Again, the input I had in mind here is normal MPEG or AVI/DivX & not VIDEO_TS folders. I have a rough idea how to make DIVX files from DVDs (I use IMTOO DVD Ripper 4) but the only way I know how to extract subtitles is with PGDDEMUX which are .SUP files. Can I use .SUP files in TDA3? If not, how else can I import subtitles? -
Q2A:Originally Posted by rock_king_my
Yes you can use celltimes text file from PGCDemux if you change its extension 'txt' to 'keyframes' (not sure of the last letter 's' but you'll see the correct format name at importing, that's from menu in the same page as timeline).
Q3: not sure of external subtitle formats supported (haven't used this feature yet
Q3 - I'm pretty sure you can open your SUP file in subtitle workshop then save it as a subrip (SRT) then import it into TDA3 using the import feature.
Tmpgenc dvd author 3 will not author my m2v files????
By biged670 in forum Authoring (DVD)Replies: 1Last Post: 28th Sep 2009, 11:10 -
TMPGEnc DVD Author 2 questions
By siluet in forum Authoring (DVD)Replies: 15Last Post: 27th Apr 2009, 20:57 -
TMPGEnc DVD Author 3 (TDA) Questions
By Brent.M in forum Newbie / General discussionsReplies: 5Last Post: 10th Feb 2008, 23:34 -
ConvertXToDVD, MPlayer and TMPGenc DVD Author 3 basic Questions
By Maikeru-sama in forum Video ConversionReplies: 4Last Post: 28th Jan 2008, 10:43 -
New to TMPGEnc DVD Author 3 - Two Questions on Video Quality
By heyjjjaded in forum Authoring (DVD)Replies: 0Last Post: 16th Aug 2007, 12:15
