I used to make vcds until I got a player that plays vcds/svcds/xvcds, etc..(mustek) and make short snippets 480480 with the nero 'infinite hold' feature, so it awaits my command to go forward on my standalone. Nice....however, I decided to up my bitrates and re-render some older vcds and use 'inifinite hold' in the file properties just before the burn.
My previous vcds hold on last frame. The new ones I am making no longer hold the last frame. The TV goes black, and that's what it holds. My previous vcds held the last frame. Yes, I am choosing 'disc at once' feature. I also tried different encoders, ie TMPGENC and Premiere plug-in LSX-MPEG, which is the way I used to do it to see if TMPGENC was doing something funky to the file. I cannot remember doing anything different the first time I made them, I have not gotten another burner, still playing them in the same standalone that the first versions work on, etc...any suggestions?
PS Nero's FAQ sucks.
ok, if no one has any idea, then how about your command sequence if any of you have done infinite hold with nero, i.e.
1-video cd
2-drag files over
3-right click file-properties-pause=infinite
4-disc at one
5-write
thanks
Sony Vegas 9.0 infinite render time?
By eli_ in forum EditingReplies: 8Last Post: 22nd Aug 2010, 18:51 -
Help! Share your infinite wisdom here!
By themalmo in forum Newbie / General discussionsReplies: 4Last Post: 8th Apr 2010, 23:50 -
DirectShow AVI Muxer + Infinite Pin Tee Woes
By JCipriani in forum ProgrammingReplies: 7Last Post: 5th Nov 2008, 17:52 -
How to create a crystal clear image in "infinite white" space
By RevolutionOfTheMind in forum Newbie / General discussionsReplies: 9Last Post: 25th Oct 2008, 17:14 -
what size of the movie a dvd can hold?
By volam in forum Authoring (DVD)Replies: 13Last Post: 27th Mar 2008, 16:37
