A while ago I received a French home video in PAL-SECAM ripped to DVD, which was recorded in widescreen even though every video was 4:3. Go figure. I'm using some of those to make another compilation DVD with TMPGEnc and now the other videos have lame vertical bars. I need to chop the bars off with as little quality loss as possible.
Thanks in advance you guys, you've been helpful with everything so far!![]()
Edit: Oops, sorry, it appears that this belongs in the DVD Authoring subforum. My apologies, I had videohelp open in two tabs.
No, you're fine in this forum for now.
What you would need to do is to crop the video to a DVD standard format, then re-encode it. There will be quality loss.
I'm assuming the video itself isn't 'stretched' or distorted. If the 'bars' are only visible on playback on a set top player, then maybe the aspect ratio is wrong.
You could post a Gspot 2.70 screen shot. (Blank the titles) Then we might be able to give better advice. Info here: https://forum.videohelp.com/topic271697.html
Dvd player plays widescreen dvds in fullscreen on widescreen tv
By Fireworks_at_Dawn in forum Newbie / General discussionsReplies: 35Last Post: 24th Sep 2012, 09:24 -
Help: LG LCD TV losing picture with vertical bars
By Dogsthorpe in forum DVB / IPTVReplies: 0Last Post: 22nd May 2010, 17:47 -
Widescreen movie on Widescreen TV with blacks bars???
By overloaded_ide in forum DVB / IPTVReplies: 14Last Post: 11th Dec 2009, 14:22 -
Fullscreen vs. Widescreen: why still airing new content in fullscreen ?
By vhelp in forum DVB / IPTVReplies: 56Last Post: 2nd Oct 2009, 15:54 -
Irritating problem (flashing vertical bars)
By weko in forum Newbie / General discussionsReplies: 5Last Post: 30th May 2008, 07:40
