Hi i would like some help understanding Something. Once i have a dvd down loaded to my Hard drive how do i see it all at once other than it stop for another file.. I am using clonedvd2.. Hope this is a easy question??? LOL
Hope you understand what i am trying to say.. Very new at this..
David
Hi thanks so much for the help.. lol Now how would i know what the ifo file is? not the VOB.. ? again sorry i am very new... would that also be with any program ?
David -
The IFO file describes the structure of the DVD. The VOB files contain video/audio/subtitles etc. If you load the IFO file then the player knows that there are multiple VOB files to play through. if you just load the VOB it plays the VOB and stops.
If you use PowerDVD or WinDVD to play your files, select Open DVD from HDD (or similar) and select the Video_TS folder. The player will work out the rest.
If you use Media Player Classic, select the IFO file and it will work out which VOBs to play.Read my blog here.
thank you.. i will try that.. do you use any that are free?
David -
Donadagohvi (Cherokee for "Until we meet again")
REALLY Organizing those Giant Black Hole Hard Drives
By ahhaa in forum ComputerReplies: 6Last Post: 4th Dec 2010, 11:27 -
dvd episode ripping? can't find hole file.
By David9799 in forum Video ConversionReplies: 6Last Post: 23rd Aug 2010, 09:20 -
svcd stoping on film before it has finished
By martin finnemore in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 18th Mar 2010, 02:43 -
how to convert a hole folder?
By alina-pia89 in forum ffmpegX general discussionReplies: 2Last Post: 10th Jan 2010, 00:11 -
Where's that freakin black hole!?
By maxamillion in forum Off topicReplies: 13Last Post: 11th Oct 2008, 17:20
