  1. I borrowed my mates Wii component cable today and was pretty impressed with the quality difference compared to the pack-in composite scart cable.
    As I've already got my 360 using the only component connections in the back of my tv I dont want to unplug one or the other each time I want to use them.
    Does anyone know if there are any simple component switchboxes or splitters that will allow both to be connected?
  2. the first one just allows you to send the signal to two devices - so no use here.
    i was hoping for a simple cheap splitter. thanks for the links though.
  3. Banned
    Freedonia
    Well, that would be the definition of a "splitter", which IS what you asked for. Since what you really need is a switch box, which you also asked for, you might look at:
    http://www.amazon.com/4-1-Component-Video-Switcher/dp/B000FCT2CK
    Ebay also has many for sale.
    May 2006
    If you are into electronic gizmos:
    http://markertek.com/
    Get a free catalog. You will be amazed at all the cool stuff out there.
