I have a sidebar [s:0b4ff9f0bc]widget[/s:0b4ff9f0bc] gadget called Uptime. it displays how long my computer has been turned on.
It reports hours, minutes, and seconds perfectly accurately. But for some reason, it says my computer has been on for a ridiculous amount of time. 177 days, 200 days, etc. the number seems to be random, but it should be 0.
can anyone think of a possible fix for this? This is really confusing and annoying...
asdf
Look for a upgrade to that gadget. It is probably just a bug.
Believing yourself to be secure only takes one cracker to dispel your belief. -
seems to be a common problem. it is just a beta...... maybe try the date format change.
http://gallery.live.com/liveItemDetail.aspx?li=9edd60d7-5810-44b4-a72e-b3416de5758b&l=1--
i guess the answer was right there in the comments section on the page where i downloaded it. seems like that should have been the first place i should have looked.
i guess me brain not work good due to lack of sleep.
anyways, i fixed it. had to edit the code, changing a couple values.
kthxbyeasdf
Cool gadget if it works - Got this from e-mail
By edong in forum Off topicReplies: 2Last Post: 1st Apr 2012, 16:46 -
Gadget to start/stop recording two camcorders at same time?
By sdsumike619 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 10th Feb 2012, 17:41 -
U-Verse Service: Reports | Comparison
By Seeker47 in forum DVB / IPTVReplies: 12Last Post: 28th Jan 2010, 21:08 -
Error reports in SVCD2DVD
By deoldeprinter in forum SVCD2DVD & VOB2MPGReplies: 6Last Post: 5th Nov 2007, 22:03 -
What is the difference between Vista basic and Vista home premium?
By davidsama in forum ComputerReplies: 18Last Post: 27th Oct 2007, 13:01
