hi
i dont know, if iam writing to the proper section, ill try anyway.
iam burning iso-s (movies) for 2-3 years. i had a nect3520a for a long time now i have a Optiarc AD-7173S drive.
i always used tdk dvd-r disks, well i have aproximatly 1000 of them. my problem is random movies keep stalling on dvd-players and i dont know why. i always used dvddecrypter / imgburn with 4x speed and verify, i changed hardware few times too.
i would use some tips how can i make safe working copies. i tried many players etc, sometimes its okey sometimes not, maybe there's some burning software options or method changes anything would be helpful
thanks in advance, bs
TDK media has changed over the past 2-3 years. Its now CMC. And some of your old disks are aging.
Your drive has changed.
If you intend to keep your optiarc drive, you will probably have to use TY or Verbatim media. Other posters will tell you that you should with any burner you use.
Older players will have more problems with your TDK media. -
It is not possible to have a fool-proof method to burn DVD in any format(-R, +R, -RW, +RW) and makes it work all the time. Unlike commercial DVD, burnt-by-user DVD is of much lower quality. Most people will stick to a best combination of DVD brand, software, DVD player for best performance (after extensive trial). Even then, it does not guarantee 100% function. It is also prone to digital rot. Your 1,000 collection says it all.Originally Posted by blas
hmm thanks for the replies, well what is TY? i can get verbatin with media code
MCC 03RG20, MCC 004 what do u think? -
TY is Taiyo Yuden. Normally you have to mail order these. Verbatim MCC discs should be fine if you don't want to mail order. I mail order all my blanks because even with shipping it's usually cheaper than to go to a local store to buy Verbatim - IF they have it in stock.
hmm i can get verbatins with code MCC03RG20, dunno if those are TY disks or not, but as i read these are fine
Joint 2 parts of movie, but after ifo files created: ERRORS at playback
By johnnyemh in forum EditingReplies: 1Last Post: 31st Dec 2008, 16:25 -
svcd preview errors & vob file errors
By kiwi76 in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 10th Nov 2008, 16:02 -
Burned DVD ISO playback errors
By Silver_Ice in forum Authoring (DVD)Replies: 1Last Post: 9th Aug 2008, 13:24 -
Pinnacle 11 - playback issues on DVD - rapid playback problems
By crven in forum Newbie / General discussionsReplies: 5Last Post: 15th Dec 2007, 09:19 -
check a DVD for errors/read errors?
By ebob in forum Authoring (DVD)Replies: 4Last Post: 5th Jun 2007, 10:53
