Hi,
I have a question about playing homemade DVD-Video (on DVD-R) on my Pioneer DVR-330. I have some DV tapes which I convert to DVD compliant mpeg using TMPGENC and then burn to DVD-Video using Ulead DVD MovieFactory 6.
However when I play the disc in my Pioneer DVR-330, from time to time the screen will turn totally black (but still have audio as normal) with the message "No Signal" for several seconds and then it will come back.
Is there anyone who has a clue on what happens? Is it that somehow my DVD-Video requires too much processing time of the Pioneer DVR-330 that it cannot handle and thus dropped video? Or just that my video is not standard and thus causing all the problems? Is there anything I can do in my video conversion or burning process that can help?
Thanks a lot in advance.
- David
First, I would try the discs on another standalone DVD player. This will help determine if you are troubleshooting an authoring issue or an issue with your player.
I suspect it is related to authoring. In which case you will need to go back and start from the beginning, verifying your output each step of the way.Google is your Friend -
I have tried it in another standalone player, and the same happens, though might be in different places of the movie. My second standalone player is a ZETA HiFi which can also serve as a DVD player.
But if I play it on my PC, it is of no problems. I suspect my CPU works faster than my standalone player's processor - but not sure.
My encoding using TMPGenc is basically using the standard bundled DVD template from the software.
Any suggestion?
Thanks a lot.
- David -
Sounds like you are not properly encoding the video. Perhaps you are making NTSC video and playing on a PAL player or PAL video on an NTSC player.
Or just using crappy media or media not supported by your players.
AVerTV HD DVR | DVI black screen!!
By r00tk1ll in forum Capturing and VCRReplies: 5Last Post: 12th May 2010, 06:22 -
Connecting Pioneer DVR-330-S to Xbox 360
By Dale08 in forum DVD & Blu-ray RecordersReplies: 0Last Post: 27th Dec 2009, 03:38 -
LCD Screen: video plays on desktop but appearing black on big screen...
By Heyjoojoo in forum Newbie / General discussionsReplies: 2Last Post: 23rd Jan 2009, 17:36 -
Remote Control Problem - Pioneer DVR-330-S
By wmedia in forum DVD & Blu-ray RecordersReplies: 4Last Post: 25th Mar 2008, 07:31 -
Screen turn black when my Pioneer DVR-330 plays my homemade DVD-video
By dcmwong in forum Authoring (DVD)Replies: 1Last Post: 6th Dec 2007, 09:58
