I have a number of SVCD mvies in bin/cue format. I would like to add subtitles to these (preferably ones that can be turned off and on). Does anyone have a clue on how to do that?
It is very easy!
Use Subrip097b to get subs. Save them as "Phillips SVCD designer Subs"
Then in Submux load MPEG file, "text.sub", new MPEG file and run program. Remember to check CVD option. Cue/bin file can be created using VCDImager ver.7.12. You can get more information here http://forum.doom9.org/showthread.php?s=&threadid=12829
Antonio S.
http://antonio.owns.it -
allright that's not too hard :) one thing tho...I do not have the original DVD at hand or anything. I mean I have custom made subs. Most of them are in simple txt format or sub format. I have several converting progs for the subs. So what extension would I convert them to?
DVD Authoring with Windows MM 2.6 OR AVS Authoring
By jagman in forum Authoring (DVD)Replies: 3Last Post: 8th Oct 2011, 04:41 -
DVD authoring ac3 out of sync after authoring but not before
By Genaugmen in forum Authoring (DVD)Replies: 1Last Post: 29th Jan 2010, 19:16 -
TMPGEnc Authoring Works v.4.0.4.24 - Authoring
By niteghost in forum Authoring (DVD)Replies: 8Last Post: 21st Jul 2009, 21:15 -
Great Article On Current BD Authoring Solutions & Future Mac Authoring
By videopoo in forum Authoring (Blu-ray)Replies: 1Last Post: 12th Dec 2008, 17:04 -
TMPGEncDVD authoring 3 with divx authoring
By buttzilla in forum Authoring (DVD)Replies: 0Last Post: 11th May 2007, 21:51
