This might be kinda of confusing so let me explain. My TV is pretty old and does not have a headphone output where I can plug in headphones. Basically the setup right now is it goes from the TV->VCR->and then it has the rca(composite) inputs I believe( I think they are called that, the red yellow and white, where the red and white are audio and yellow is video).
Basically what I want to know is, is it possible that there is some sort of adapter connector thing that you first plug in the rca port, and from there you plug in the 1/8 headphone jack.
Prolly not even possible but worth a shot.![]()
Results 1 to 11 of 11
Most amplified headsets such as wireless models come with RCA connectors. You can use a Y splitter cable for left and right. Ask at any Radio Shack.
http://www.kiva.org/about -
Aside from an RCA to headphone adapter, you can also put your own headphone socket in.
I did that on an old TV, opened it up, drilled a hole in the cabinet for a headphone socket (about 50 cents) and connected the speaker wires to that. When a headphone plug is inserted it cuts the speaker wires. Easier to work with the big 1/4" size than the walkman size 1/8".
As always, keep well away from the high voltage on the picture tube, don't call me if you electrocute yourself, objects are closer than they may appear, etc, etc. -
heh, i think i will just get a wireless headset then. I would probably get electrocuted hehe. Whats a good wireless headset?
Many of them. They come in IR and RF models. IR (infrared) goes accross the room. RF can cover the house but usually is on 2.4MHz so may interfere with Wifi or other 2.4GHz gadgets. Try to find one that uses a different frequency band than WiFi or your cordless phone.
Headphone amps, most audio or A/V receivers, powered computer speakers often include a headphone output. Be sure to get something with a volume control.
Yes. Sold at Radio Shack and Walmart.
thanks guys, i will look into it. any specific models though hehe? you guys kinda avoided the question just giving me general knowledge about them. Whats a good brand and model that is decent but cheap?
Last time I bought one was 1999 or so.
Here are a bunch. Read the user reviews. Small issues are important.
http://www.amazon.com/Wireless-Headphones-Accessories-Supplies/b?ie=UTF8&node=509316
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&DEPA=0&Description=wireless+headphonesRecommends: Kiva.org - Loans that change lives.
Philips is the usual suspect, or Radio Shack, or Monster
With cheap headphones, first look for something comfortable. Everyone has different shaped heads, and ears, and after an hour or so if it pinches at all you'll know it.Originally Posted by moomooemu
Sound quality too of course, but probably less difference will be noticed. Maybe check for bass response.
I run my TV sound into the AUX of the stereo. Then I can use the graphic equalisers. From that I can plug in my wireless headphones when I want to watch TV at night and not bother anyone.
Tv with no headphone jack AND rca audio outputs
By gordes04 in forum DVB / IPTVReplies: 27Last Post: 23rd Jun 2013, 22:39 -
Plug DVI/HDMI adapter to DVI video card?
By Stealth3si in forum Media Center PC / MediaCentersReplies: 25Last Post: 23rd Dec 2010, 20:32 -
No Ethernet port and wireless adapter but want to connect HS Internet
By coody in forum ComputerReplies: 1Last Post: 11th Dec 2009, 14:57 -
What's that thing called that splits an s-video/RCA(Composite)?
By RoganSarine in forum Capturing and VCRReplies: 10Last Post: 31st Dec 2007, 05:06 -
is the IEEE 1394 Adapter port necessary...
By roochie in forum MediaReplies: 15Last Post: 15th May 2007, 20:03
