I just discover a very strange video length problem.
The only player which can play back m2v file on my system is media player classic. but MPC shows the video's length incorecctly. for a 11 seconds video, MPC shows that it's only 9 seconds. and after MPC plays to the 9 seconds point, though the time counter in MPC stops (stops at 9 seconds), MPC will keep playing to the real end of 11 seconds. then I multiplex the m2v with a audio file to get a mpg file, now MPC shows the length of the mpg file correctly, that's 11 seconds, and playback the mpg file without any problem.
I use gspot to check both files, m2v and mpg, both have the same number of frames.
the m2v makes a big problem for me since I will import it to a music production software to produce bgm and sfx.
in the music software, the m2v file has the length property of 9 seconds, this video clip on the video track can't be longer than 9 seconds. and the whole content ( 11 seconds' content) of the m2v file will be played back in 9 seconds. but if I scrub on the timeline, the video will stop at the 9 seconds point, and the last 2 seconds can't be displayed. Don't doubt my project settings please, I'm sure the project and the m2v file have the same frame rate. btw, in the music software, I should choose the directshow video engine for video display, if choose directx video engine, the video monitor window is black. I don't know which engine MPC uses to display video.
I have import the m2v file into Premiere, the length property and playback have no problem.
I use as many methods as possible to get a m2v file, such as output by Premiere, by Final Cut Pro, multiplex then demultiplex. It seems that as far as it is a m2v file, the length problem does exist. and if it's a mpg file, the problem is gone.
How did you create the m2v? or is it downloaded? captured?
Probably it is a glitch of MPC (the version I'm using is an old one,
but I do know what you're taalking about),
or a problem of the current mpeg-2 decoder, or both things. ^.^;;
Don't know if this is a solution, but you could try an mpg stream with
no audio instead of an m2v file. Good luck!
I have tried every method possible to make a m2v file, just as I have said, rendered by different edl softwares, demultiplex a correct mpg file. and as far it's a m2v file, it has problem.Originally Posted by Baldrick
thanks for reply. at present converting to a mpg file is an alternative method.Originally Posted by Midzuki
MeGui video length problem
By killerteengohan in forum EditingReplies: 1Last Post: 8th Feb 2012, 02:21 -
Video is Crazy!!! Very strange problem with FourCC!!
By Cauptain in forum Newbie / General discussionsReplies: 7Last Post: 22nd Nov 2011, 16:32 -
Mkv to mp4 transcoding: strange output files (double length)
By TOMillr in forum Video ConversionReplies: 0Last Post: 11th Sep 2010, 13:42 -
Strange problem - zero length files *only* after copying to DVD
By GregSchmidt in forum Authoring (DVD)Replies: 7Last Post: 28th Apr 2010, 11:05 -
AVCHD PAFF Deinterlace / Video time length problem
By tat2jr1 in forum Video ConversionReplies: 4Last Post: 24th Jul 2009, 03:58
