I recently purchased a new hp laptop and i just burned a movie to see if it worked and when i watched the movie it had all four sides with the black bar i guess its called windowboxing. When i checked the options before i burned the movie i chose normal full screen. But i don't know why its not showing full screen i've tried several dvd players and it plays the same on all of them. Its a divx movie that i burned on a DVD+R using Windows Movie Maker. does anyone know how i can remove this so it doesn't show up on every movie i burn?
...stop using windows movie maker. :P
Sounds to me like you haven't scaled the DivX file to full screen. I'm not that familiar with Windows Movie Maker, so I couldn't tell you exactly how to do it.
Personally, I own a DVD player that plays DivX files. They're incredibly cheap these days and they don't require you to hassle with re-encoding to watch DivX stuff on your TV. -
I don't know of any programs to use to burn movies like i said this was my first time. What software do you recommend i use that doesn't show up with the windowboxing and isn't to expensive? the computer came with roxio installed but i don't like the menu's it creates for the dvd. i wanted to upgrade to nero 8 but i don't know if this is the one i need.
You could try ConvertX2DVD.
But I agree, it saves a lot of time, effort, and money to just buy a Divx capable player.Google is your Friend
adding black to the sides of an image (windowboxing)
By maca in forum Video ConversionReplies: 3Last Post: 30th Jan 2010, 14:21 -
What is the deal with the f**king windowboxing?!?!?!
By explosionfoot in forum ffmpegX general discussionReplies: 9Last Post: 20th Apr 2009, 13:25 -
How to get rid of windowboxing?
By Levina in forum MacReplies: 8Last Post: 10th Jun 2008, 19:47 -
WINDOWBOXING... Caused by DVD Player / Plasma...???
By Lathe in forum Newbie / General discussionsReplies: 4Last Post: 22nd Nov 2007, 18:43 -
How to get rid of Windowboxing on a DivX file for Front Row
By hauns in forum MacReplies: 0Last Post: 9th May 2007, 13:44
