Hi,
Well I'm finally signing up for digital cable and a high def dvr. (haven't got it just yet though - this week).
My tivo subscription (a one year deal) will run out at the end of year. I plan to let it lapse and just start using the high def dvr. Only downside is the cable dvr is slightly lower in capacity - 15 hour high def recording and 60 hour standard (scratch that its either or so high def takes up more space and less analog recording, but it has a dual tuner which will be nice)
My questions are:
How easy is it to hack a TIVO SERIES 2 model?
What capacity can it be upgraded to?
What functionality can be had WITHOUT an active service plan?
Can the official TIVO-TO-GO wifi adapter be used on a hacked model for wifi streaming files off it?
Would it be better to simply put the TIVO in storage in case I decide to end the high def cable and use it later instead of buying another TIVO hardware unit?
Thanks in advance.
Results 1 to 9 of 9
Is hacking a TIVO legal???
Yoda, Yoda, Yoda... -
I was just trying to do a little ribbing on posting a questionable hacking question...
Everyone has stayed clear so I guess I succeeded. lol -
I'm curious about some of this. Does the tivo work without paying for the service? Is it just a useless box without it?
His name was MackemX
What kind of a man are you? The guy is unconscious in a coma and you don't have the guts to kiss his girlfriend? -
That's what I'm wondering.
Can it be set up to be used a ye olde vcr? If it could be hacked with a large harddrive and use only as a programmable recorder I could live with that.
Though I may also just box it up.
Ideas???Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
"I've got a present for ya!" - TTWC
Thanks taotewingchun. I've saved the reference link it posted and check it out later.
Hacking DVD5
By SomeRelax in forum MediaReplies: 8Last Post: 8th Nov 2011, 05:49 -
Multiple questions about HD video capture (broadcast, Happauge, Tivo)
By jpt85 in forum DVB / IPTVReplies: 36Last Post: 13th Apr 2011, 20:02 -
Dish DVR 625 & Tivo questions
By darkcyber in forum DVB / IPTVReplies: 20Last Post: 10th Jan 2010, 20:56 -
Hacking a Sony RDX650
By Khelben in forum DVD & Blu-ray RecordersReplies: 0Last Post: 2nd Jun 2009, 17:08 -
LG DVD Hacking / Remote
By Spikey in forum DVD & Blu-ray PlayersReplies: 0Last Post: 28th Aug 2007, 06:33
