Not a new item but if you are looking to extend your network in your house and don't want to do any wiring this might be an option for you.
http://www.netgear.com/Products/PowerlineNetworking/PowerlineEthernetAdapters/HDX101.aspx
* Turns any electrical power outlet into a network connection
* Enables high-quality video streaming, gaming and VoIP over a home network
* Delivers up to 200 Mbps to any outlet†
* No software required—just plug and play
Some other network options:
Netgear HDX101100NAS
Powerline HD Ethernet Adapter
Netgear HDXB101100NAS
Powerline HD Ethernet Adapter Kit
Make em a bit cheaper , and I'm go to go. Are there any latency issues if you want to game (lan party)in-house?
doesn't always work -- but when it does .. works pretty good----- (also sold by other companies with similar products) ...note that most of these (like all) run REALLY hot ...
WDTV LIve + Netgear Powerline/WD Livewire + external USB HDD's need opinion
By tube435 in forum Media Center PC / MediaCentersReplies: 7Last Post: 7th Oct 2010, 10:38 -
No Ethernet port and wireless adapter but want to connect HS Internet
By coody in forum ComputerReplies: 1Last Post: 11th Dec 2009, 14:57 -
HP Ethernet Driver
By Sportster Freak in forum ComputerReplies: 14Last Post: 19th Mar 2009, 19:02 -
How does powerline work?
By yoda313 in forum ComputerReplies: 4Last Post: 13th Jul 2008, 15:49 -
wifi to ethernet?
By iThinkYouBrokeIt in forum ComputerReplies: 4Last Post: 31st Oct 2007, 09:49
