I've been running W2K SP4 for many years, and don't recall seeing this before. Last night I had a USB connected hard drive turned on, but it hadn't been doing anything for well over an hour. The only app I was running was my browser. Left the room several times to go check on other things, and a few times when I came back I found an "Unsafe Unmount" of USB warning up on the screen. It was totally bogus: I never dismount USB without shutting it down properly in the System Tray; the drive was definitely still online -- I could read or write to it with no problem. So I just kept killing the warning screen, but it would return after awhile. So far, it appears to be annoying but harmless.
AV and spyware defs are up to date, and full scans have been done. I did a quick Google search, and this sort of issue is apparently not unheard of, but I did not come away with any enlightenment. I'm hoping this is just some transitory glitch. Has anyone seen this before, and know what may be going on ?
Looking for Rare / Obscure / Hard-to-Find Films ? Check out http://rarefilmm.com/ , and also its Requests & Discussion forum http://rarefilmm.chatango.com
Is the external enclosure powered by the USB port or with an external power supply?
If powered by the USB port check your system power supply, mobo or mobo temp.
If powered externally, check the external PS and external box.
Drive spin down due to power problem will give this symptom.
May only be safe because the drive is idle and cache is clear. -
Another thought.
Some external boxes will operate intermittantly if the drive is jumpered cable select rather than as master. -
Thanks for your ideas -- I will check them out. Both the drive and the enclosure have been in service for awhile with no prior problems.Originally Posted by oldandinthe way
How ? Do the PS bricks of these enclosures just suddenly go flakey ?Originally Posted by oldandinthe wayLooking for Rare / Obscure / Hard-to-Find Films ? Check out http://rarefilmm.com/ , and also its Requests & Discussion forum http://rarefilmm.chatango.com -
I never dismount my USB HDD in the System Tray....I just turn the power off and have never had a single problem. I just now did it about 2 minutes ago too.Originally Posted by Seeker47
Yep.Originally Posted by Seeker47
To test them you need a voltmeter to check the output. Since it is DC, you should simply see a constant voltage. However, if the part of the electronics that does the conversion is on the fritz, the voltage may be fluctuating too fast to see on the meter and you'd need an oscillope. Also, the voltage really needs to be measured when connected to something drawing current.
BTW, I rarely use the tray item to safely unplug USB devices - especially since some refuse to give the "it is now safe to....". USB is designed to be hot-swappable and compliant devices should correctly handle the unexpected (this means the device itself and the Windows driver). Of course, unplugging a hard drive in the middle of a capture etc is rather foolhardy but isn't any worse than ann unexpected power failure.
Windows 7 Stuck in "read only" mode for USB THumbs and SD Cards etc..
By nerys in forum ComputerReplies: 26Last Post: 1st Mar 2012, 02:03 -
sony DVD Recorder RDR-GX257 "unknown disc "msg
By corpjet in forum DVD & Blu-ray RecordersReplies: 2Last Post: 16th Feb 2010, 12:08 -
My Samsung HT-TZ315 with Divx playback and "USB host" Blew up!
By BaggyB in forum DVD & Blu-ray PlayersReplies: 5Last Post: 12th Jun 2009, 05:28 -
Need help...Newbie who's just bought "EasyCap" USB Capture Device
By RICHM0802 in forum Capturing and VCRReplies: 1Last Post: 19th Sep 2008, 01:18 -
Philips DPV-5992 not recognizing a USB HD - "Input Invalid"
By benvid in forum Newbie / General discussionsReplies: 6Last Post: 21st Jun 2008, 17:02
![Computer details: [This list is SELDOM up-to-date !]
Shuttle SX48P2, Q9550, 4Gb.
ATI Radeon 45__ (?)
Win-7 Ent. x86
WD Black 500Gb. + 1Tb.
Shuttle SP35P2 Pro,
Intel Xeon 3230, 8Gb.
ATI FireGL V3400
Win-7 Ultimate x64
Shuttle SH67H3 (i5)
w/ 16 GB. RAM &
Win-10 Pro
SSD + HDD
LG Blu-Ray burner
[acquired used as an already-HTPC,
though not yet assigned to that task]
Shuttle SH67H3 (i7)
w/ similar config to the one above
and others
[also (reluctantly) perform some "IT-by-default"
services for an office, with other computers
there . . . ]
Various older model Lenovo laptops, like T-40
series, T-60
IPAD Pro (Gen. 2)
Video Gear includes:
Oppo 95-BR
Pioneer 520, 640, 460
Toshiba 32HL67
Panasonic G-25 plasma
Pan V-series 58 plasma.
TBC-1000 & other assorted gizmos
Panasonic 4820-SVHS
& various other VCRs
Various Betamax gear
Var. video streaming boxes Comp](/images/buttons/computer.gif)
