Hi guys,
I got the fallowing problem, im trying to use this sofware to add a subt to an avi file, i got installed K Lite codec pack full vers, but every time i try open the avi file or to output it, the program closes, i dont know whats going on with it, i had never this problem b4 and now i cant do anything since i re installed winxp.
Any suggestion?
Note: on enviromental setup i got direct show multimedia file reader as a priority.
thanks
Too late for suggestions. (Which otherwise would have been: Don't ever install codec packs. Specially not K-Lite)
/Mats -
In my experience, uninstall doesn't work.
Spent weeks trying to restore video playback/readability once when I was young an stupid, after a K-Lite intermezzo. Actually never regained full playback capability until I did a new Windows install.
Try tools like codec sniper to get rid of what K-Lite uninstall leaves behind.
Remove everything not installed by Windows default.
Once you have a clean system, install the codec you need as you need it. Use GSpot to identify what codec a particular file wants.
/Mats -
Thank you
i unninstalled klite codec and installed directvobsub and ffdshow, now i got a video with no image but at least the subts are there. -
Just ffdshow goes a really long way as far as video decoding goes. It also renders some subtitle formats, so directvobsub may not be needed...
/Mats -
Problem solved
K lite did not use to have this kind of problem b4 with tempgenc.
thanks -
It's not that K-Lite has a problem with TMPGEnc - It's the whole video sub system of your computer that has problem with K-Lite. Installing a codec pack to fix the playback of a video file is like hunting a mosquito in your kitchen with a shot gun. You may fix the mosquito, but your kitchen will be a mess.Originally Posted by lancerx
/Mats
Multiple Files & Resolutions In Tempgenc Xpress 4
By TufrThanu in forum Video ConversionReplies: 0Last Post: 9th Aug 2009, 14:21 -
error while burning DVD DL using tempgenc dvd author
By rgpai9972 in forum Authoring (DVD)Replies: 2Last Post: 2nd Jun 2009, 21:15 -
tempgenc authoring works 4 - can I save the edited clips?
By yvonne_1980 in forum Authoring (DVD)Replies: 2Last Post: 24th Mar 2009, 05:59 -
video card problem causing watching movies problem?
By vipertongn in forum ComputerReplies: 3Last Post: 11th Jun 2008, 11:39 -
Tempgenc DVD Author small file
By EPLindblom in forum Authoring (DVD)Replies: 1Last Post: 13th Feb 2008, 21:39
