I’m currently downloading a DVD that comes w/ an ISO file that is 6.8GB in size. It also comes with an .MDS file. I have a question as to what the .MDS file is for and do I need it to burn the ISO file in Toast 7?
I have googled on this and the answers vary. One say that you don't really need it. Another say that the .MDS file contains info about dual layer (DVDs ripped w/ dual layer).
Any insights?
Thanks.
I’m planning to either burn it to a dual layer dvd or compress it into a single dvd5. Not sure yet. I think I might want to preserve the best quality and burn it to a dl dvd.
	When I do a build in ImgBurn I get both the .ISO and .MDS file. I have only used the build mode recently when making an ISO that needs to be burned to a DL disk so it may be the info on where the break is. If I try to open the ISO in ImgBurn to do the burning it tells me to use the MDS file. Steve W.
  how to play mdf fileBy jyeh74 in forum Newbie / General discussionsReplies: 5Last Post: 2nd May 2015, 11:01
  Tool recommend for *.avi ---> DVD(iso) and ripping a DVD to *.iso file?By pxstein in forum Authoring (DVD)Replies: 4Last Post: 11th Jan 2011, 16:51
  1080i .TS Video file to Blu-ray .ISO file Help !By SiNnOFf in forum Authoring (Blu-ray)Replies: 19Last Post: 3rd Nov 2010, 14:12
  ISO file bigger than original video_ts file.By bbanderic in forum DVD RippingReplies: 8Last Post: 20th Feb 2010, 20:04
  Why Does ImgBurn Only Sometimes Build an MDS File with ISO File?By cyberboy in forum Authoring (DVD)Replies: 1Last Post: 14th Aug 2009, 00:36
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
