I am using Nuendo2.2 for some audio editing and have faced this problem
I have made some music files in ac3 format for which I used vegas6 and burnt them on dvd to play on stand-alone player. They play well but I found that the surround volume is very low. Now since vegas can not edit ac3 file and I had deleted the source mono files I tried to open in Nuendo with channel split and used volume gain for surround channels. They played well as far as they were played through Nuendo itself but when I re-exported to ac3 the file was created. It seems ok but there is no volume at all in any channels. There is no volume heard even after turning the volume control to its highest.
What could be wrong?
Results 1 to 1 of 1
DVD playback problem, possibly a file structure problem?
By snuhmcsnort in forum Newbie / General discussionsReplies: 8Last Post: 17th Aug 2010, 04:23 -
problem after problem - dvd architect, not enough room in temp files
By jgeck90 in forum Newbie / General discussionsReplies: 7Last Post: 1st Dec 2008, 03:35 -
HDD problem, gigabyte's easy tune major problem and etc....
By MidnightMike in forum ComputerReplies: 4Last Post: 28th Jul 2008, 21:57 -
video card problem causing watching movies problem?
By vipertongn in forum ComputerReplies: 3Last Post: 11th Jun 2008, 11:39 -
WinTV PVR 150 problem and Geforce 7600 GS problem
By deck in forum Capturing and VCRReplies: 5Last Post: 16th Jun 2007, 03:03
