I downloaded the new version of SUPER, and it's got a bug in it. When loading up SUPER, i get an error, showing a box, with a red "X" in it with a circle around it. Then, it shows a single quote ("), saying "not a valid integer value. I have two computers, both with SUPER installed, and both have the bug. So does anyone experience the same thing, and if they know of a fix? Sometimes, it won't let me convert video files with this bug. thanks
I saw a post about this recently on the SUPER forums, and here's what they said about it (assuming it's the exact same bug
Original post: http://www.w3exchange.com/p5965-2007-11-28-235020.html#p5965the "not a valid integer" bug has been fixed in the future release.
simply close SUPER(C) while the AVI Output Container is selected (not the cuurrent one)If cameras add ten pounds, why would people want to eat them? -
thanks! i will try that! I would usually drag and drop videos to be converted, but i tried using the "open" function, and it actually loaded a file without the "not a valid integer" msg. But i will definitely try the method you mentioned, since it's a lot easier to drag and drop, especially when doing a batch conversion.Originally Posted by Ai Haibara
thanks again!
What is AVI(for pocket PC) in Super?and keep aspect ratio in Super ?
By SingSing in forum Video ConversionReplies: 2Last Post: 19th Dec 2009, 21:05 -
SUPER converter program has Encoding Failure Error
By kerrex_2006 in forum Video ConversionReplies: 4Last Post: 26th Sep 2009, 13:44 -
SUPER - is it really super? (a behind-the-scenes look)
By BaronJT in forum Video ConversionReplies: 5Last Post: 2nd Aug 2009, 08:29 -
Error while converting to Mpeg4 with Super
By murthyavr in forum Video ConversionReplies: 2Last Post: 12th Jun 2009, 05:06 -
Get many error messages, AviSynth error message and meGUI error
By MKVcrazy in forum Video ConversionReplies: 0Last Post: 25th Aug 2007, 16:41
