Hi all. i burned an .iso image file using magicISO int imation DVD+RW but now when i put it in my dvd player it does not play. But it works in my laptop!! All i see is black page when i press menu i get this word "prohibited" and also i can't forward .... When i play the dvd in my laptop it asks for lunguge and after selecting it plays the dvd just fine but in dvd player i get black screen!!
could any on tell me what might have been the problem and how to fix it?I also burned another.img file using magicISO and it works just fine.Thanks
Probably a TV system problem (PAL/NTSC). Could also be a Region Protection Code issue, but that is more unlikely, as Video DVD distributed as ISO rarely has any region code.
/Mats -
Thanks for your reply . Is there a way to check if the DVD is PAL or NTCS from the iso file?
Not that I know of. But mount it with Daemon Tools, load a VOB into GSpot and check the frame rate. 25 fps=PAL, anything 23.976, 29,???=NTSC
What player(s) have you tried it on?
/Mats -
i check it and it is pal but may be manue has problem that it doesn't show up in dvd player!!
Out of ideas. Anyone else?
/Mats
Problem Playing Authored/Burned Dvd on DVD Player
By djgazzabhoy in forum Video ConversionReplies: 10Last Post: 24th Nov 2011, 15:15 -
No sound when playing playing burned DVD on stand alone player
By ibzomie in forum Newbie / General discussionsReplies: 2Last Post: 23rd Aug 2010, 14:11 -
Problem Playing DVD I burned
By hollywoodfussell in forum Newbie / General discussionsReplies: 4Last Post: 8th Sep 2007, 08:46 -
Playing DVD burned slide show on DVD player problem
By zenfoos in forum Newbie / General discussionsReplies: 4Last Post: 29th Aug 2007, 22:37 -
Ripped/burned AVI DivX files not playing in pc or DVD player
By perceptionist in forum DVD RippingReplies: 13Last Post: 4th Jun 2007, 04:55
