Results 1 to 12 of 12
    Dec 2007
    Ok well , i'm trying to put a trailer together for a class project and one of the scenes I need is in Independence Day , kind of at the beginning of the movie where the spaceships are disconnecting from the main ship and are coming down to earth.
    Well anyways I've used DVD Decrypter/DVDshrink/DVDFab and Ripit4me and every single time after they are done I can't find some scenes IE the one i need and ones where they are playing Chess in the park etc , I've checked every single VOB file and they are just not there it's freaking me out since the project is due next week.
    Help Pls
    PS , also does anyone know of a scene in a movie where Christ is in the Air after his ressurection?
    tks in advance
    Apr 2004
    Miskatonic U
    The scene with the ships dropping out are in both versions, so it is there and you just need to look more slowly. If I remember rightly, the shot is only a few seconds long so FF may skip over it.
    The chess game might only be in the extended version, so make sure you rip the right one.
    You might find a Christ scene like the one you want toward the end of Dogma, but it's been years since I watched it, so I could be wrong.
    Read my blog here.
    Dec 2007
    no the scences are totally missing , the disk isn't scratched either , it's weird.
    Apr 2004
    Miskatonic U
    Which version are you ripping ?
    Have you selected a single branch in DVD Decrypter ?
    Read my blog here.
    Dec 2007
    The Limited Edition ID4 one and ripping the entire DVD
  6. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    Use DVD Decryper. Click on Tools -> Settings -> File Mode (tab). Tick Multi-angle Processing, and select angle 1. Try ripping again and see what you get.
    Read my blog here.
    Dec 2007
    Did exactly what you said and i got the same thing again and again , it's like a few scenes are missing atleast 7 mins of film is gone between VTS_06_01.VOB and VTS_06_02.VOB , it's kinda weird , i've checked every file in the folder also to see if it's someplace else but it's not there.
  8. Member stars's Avatar
    Apr 2006
    In the Lighthouse
    Hi I would do it this way..
    1- Copy the dvd to your hdd with ripit4me (movie only) and discard the the dvdshrink process
    2 - demux the movie with pgcdemux (now you will have a .m2v and .ac3 file)
    3 - Open the .m2v file with mpeg2schnitt (the .m2v and .ac3 file must have the same name NOT same extension)
    4 - cut out the wanted part and save it (output will be .m2v and .ac3 file)
    5 - If you want a mpeg file mux the .m2v file and .ac3 file with ImagoMPEG-Muxer
    stars...
  9. dimpayne,
    might be a silly ?, but you never really stated that you ACTUALLY viewed your DVD to verify that the scenes are ACTUALLY there. obvious I know.
    Dec 2007
    K will give that a try Stars
    Noki , yes i viewed the movie 2 times on my DvD player and the scenes were there w/ the origi movie disc , but when i ripped them and then transferred the files into Sony Vegas they didn't show up.
    it's kinda weird that the scenes i need to make the trailer aren't there though , maybe somebody upstairs doesn't want me to make it =p
    Dec 2007
    Well i downloaded everything but I can't figure out how to demux it , sigh oh well
  12. did you play the RIPPED files with a software player to verify the scenes? try to match the time (playtime) with the settop viewing and software viewing.
