    Dec 2007
    i am trying to make an 80's dvd (equivilent to 1 saturday morning) and i want to adhere to this format:
    cartoon segment-commercial-commercial-commercial-cartoon segment-commercial-commercial-commercial
    i want the specific commercials to play in random order while the cartoon segments are not random & still sticking to the format above.
    is this possible?
    thank you for your time.
    meshnut
    A random-play DVD? No, I don't think so.
  3. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    DVD Lab Pro can probably do this - not truely random, but near enough for government work - with a little coding. You will find some of what you need in the manual, and the rest in the mediachance forums. Search for random
    Read my blog here.
  4. Member GeorgeW's Avatar
    Feb 2005
    Combine the commercials into one Title with a chapter mark at the start of each commercial. Then in Encore create a Title Playlist to play Cartoon-segment-1 / combined-commercials-1 / Cartoon-segment-2 / etc...
    Burn this to DVD Folders on your hard drive.
    Then open the DVD in PGCedit, and double-click the combined-commercials Title, and for PG Playback, select SHUFFLE (you can select from Sequential / Random / Shuffle). Also change the number for "programs" accordingly to how many additional commercials you want to play.
    Check how it plays in PowerDVD and a Set-top DVD Player...
    Regards,
    George
    Dec 2007
    thank you very much for all your help, i shall give it a shot =)
    DVDWS2 would work too, I bet. Interesting. I shall try it too, eventually.
